0W-8 here. I use 0W-16 since WM will always have it in stock.The new Camry specs 0w16![]()
620,000 miles of personal experience driving Toyota hybrids.That doesn't answer my question. Why are you confident that a 0w-8 is suitable for a 2008 Prius? Personal experience? Japanese recommendations?
I do hope your hybrid battery gets you there.Um, yes. I'd like this car to last for at least 5 more years.
So what grade of oil are you running in the Prius??But how is the recommendation for a 2024 Camry relevant to a 2008 Prius?
It isn't. Totally different powertrain design.But how is the recommendation for a 2024 Camry relevant to a 2008 Prius?
I've never changed the oil in either Prius but that being said I've just returned from Walmart with a five quart jug of 0w-20 Valvoline Restore and Protect for the 2010.So what grade of oil are you running in the Prius??
Solid choice from what I’ve saw results hereI've never changed the oil in either Prius but that being said I've just returned from Walmart with a five quart jug of 0w-20 Valvoline Restore and Protect for the 2010.
Let's hope so.Solid choice from what I’ve saw results here![]()
First thing I did when I got it home was clean the cooling vent. Purchased an aftermarket vent filter as well.I do hope your hybrid battery gets you there.
Clean the hybrid battery cooling vent.
Highest quality motor oil will ultimately influence both durability and oil consumption, much more so than viscosity.
"0.5% improvement in fuel economy !"
(The BITOG Chant.)
Sure.
I don't usually see it with engines that that have good oil change history. I have seen it many times, usually in cases of neglect, but I haven't really tracked it.Thanks Two. I love seeing the cut open filters.
For those of you who are more into this than me, are these carbon pieces in the filter not something you see with traditional motor oils?
Some five quart jugs at Walmart are a half-quart low (4-1/2qts).Oil consumption seems the same, or very slightly lower. Oil level was perfectly between the min and max lines right after the last filter change, and was right at the min level right before this filter change. I added just enough to get it right back in the middle of the range.
Pouring from a 5qt jug, it's really just a guessing game on how much I added to get the level up. I need to get myself some little graduated container for topups.
No they are notSome five quart jugs at Walmart are a half-quart low (4-1/2qts).
Any updates?Yes, the chunky bits don't point to the greatest maintenance history, but still, it doesn't smoke, clank, knock, or rattle... and it gets 43pmg+ in 100% around town driving.
Hopefully R&P cleans it up good enough to last until my daughter graduates college.
Daughter in college usually equals more time needed to rack-up 3-4k in mileage. It would take my daughter the entire Sept-June time-table to drive 5k around Campus and on weekend shopping jaunts.Any updates?
