What’s the history of OCI’s? Time, distance and oil used? I’m curious how the engine got that dirty in 65k? Thanks for this post.
Like to know a bit more from the OP about engine noise, low end torque capability and fuel mileage vs previous product installed and run. These are just a few additional factors I use in making an oil choice.The UOA suggests that VRP is a fantastic oil that just happens to clean. It's not *just* for cleaning.
Where are you seeing an engine that got dirty in 65k miles?What’s the history of OCI’s? Time, distance and oil used? I’m curious how the engine got that dirty in 65k? Thanks for this post.
Yep. That prompted me to buy the last model with this engine: 2025 3.5 ES 350 F-SportSide note: What a great engine that 3.5 V6 is. It still amazes me that they discontinued that engine and replaced it with a Turbo-4.
/smh
Well….look at the mileage in the UOA and the filthy filter.Where are you seeing an engine that got dirty in 65k miles?
On worn in, non V8 engines you will likely see total wear metals at 2ppm (+/- 1) per 1000 miles with a good oil choice and interval with frequent long trip usage. I am too lazy to gather the data, I am sure someone in the forum has this handy.So is this perhaps the best UOA bitog has ever seen?
I just have never seen a UOA with this low of wear metalsOn worn in, non V8 engines you will likely see total wear metals at 2ppm (+/- 1) per 1000 miles with a good oil choice and interval with frequent long trip usage. I am too lazy to gather the data, I am sure someone in the forum has this handy.
The total bore swept area and the sump volume cannot be ignored and should also be a normalization factor in the calculation though.
A 1.5L 4cyl with a 5 liter sump will likely show better results than a 5.7L V8 with a 5 qt sump!
The only thing that UOA tells you without conjecture is that 5,000 miles on that engine in those conditions was too long for that oil to stay in grade. Any other superlatives gushed on this oil, there’s no evidence that other oils with the same certifications/approvals wouldn’t perform statistically identically, especially considering this family of engines is known to be very easy on oil.The UOA suggests that VRP is a fantastic oil that just happens to clean. It's not *just* for cleaning.
Doubtful, since a UOA truly only tells you if the oil itself is still serviceable.So is this perhaps the best UOA bitog has ever seen?
Dont worry bro no ones gonna take your HPLDoubtful, since a UOA truly only tells you if the oil itself is still serviceable.
Take a flip on the other (non-Swifty attitude that some folks seem to have for VRP) side… if someone had an engine with a known problem, like an already-spun bearing or worn timing chain tensioners, and poured in new oil and then 5k later did a UOA, is it the oil’s fault that it picked up the material from the previous damage? No.
Fair enough, but it's not just this UOA. There aren't a ton of VRP UOAs on here yet but those that are posted are consistently showing excellent wear metals normalized by mileage.The only thing that UOA tells you without conjecture is that 5,000 miles on that engine in those conditions was too long for that oil to stay in grade. Any other superlatives gushed on this oil, there’s no evidence that other oils with the same certifications/approvals wouldn’t perform statistically identically, especially considering this family of engines is known to be very easy on oil.
Single digit ppm variations are literally noise, think of trying to find Waldo standing in the middle of Tokyo.
Slight change in topic but what is it with these guys on YouTube doing filter exams with R&P after driving 1000-2000 miles on the oil. You know these guys are probably pretty anal with their vehicle maintenance to start with. So how freaking dirty could their engines be? I want to see the filter media after 4000-5000 miles.
True, however I'd say that most people (in other words non-BITOG people) I encounter don't care about oil or oil changes and either follow OLM or go further. This is why I'm cautious about buying used cars.The posts of clogged oil filters are from neglected turds that are obviously being cleaned out. Your average engine shouldn’t be THAT DIRTY.
I didn't post anything about the filter. The engine has been well cared for over the 65K miles with 5k OCIs using quality oils.Well….look at the mileage in the UOA and the filthy filter.
The UOA states fuel dilution is "<0.5" which basically means none or very low. Also the Toyota 2GR is not a straight direct injection engine. It has both DI and port injection.Vis drop is prob from fuel. Looks great. Great low wearing Toyota engine.![]()
B/S labs can't measure fuel accurately.The UOA states fuel dilution is "<0.5" which basically means none or very low. Also the Toyota 2GR is not a straight direct injection engine. It has both DI and port injection.
This is the only thing about VRP that concerns me. It tends to shear down to a 20 weight. 5W-30 should be in the 10 viscosity range.
