Valvoline R&P 5w-30 5k mi; 2001 Crown Victoria 149.4k mi
This report is from my 2001 Ford Crown Vic with 149k miles on it, everything is stock and it is used as a highway commuter, so pretty light driving, occasional WOT, but I don't necessarily drive it like a grandpa. Oil filter was a Champ Labs PH820XL, I will post a C&P after this of it. OCI was from 4/4/25-7/15/25, 5,161 miles, I had to add 1qt at 3,000 miles. Ambient temperatures have been very hot, mid 90s, very humid and lots of rain, A/C running for longer periods, I am in South Georgia.
The next oil I put in it was SuperTech 5w30 FS HM, I am going to do a UOA on that to see how it looks, particurally the wear metals compared to this R&P. Then maybe I'll do some ST 5w20 and see how that looks. I also put a Pronto/PG filter on this time.
Filter C&P: https://bobistheoilguy.com/forums/threads/champ-luber-finer-ph820xl-c-p.398551/#post-7331314
Why did you only use R&P one time?
This was my second time using it on this car. But it was not needed, engine is extremely clean and looking through the oil fill port the top of the heads are still practically grey. I just ran it to do a little cleaning and see what it would do.
The only concern would be the Al the first run, but it came down. I would have expected Fe to be elevated based on the filter. What is the history with oil pumps on this engine?
I agree the Al is worrying, it went down but could've just been a fluke. Weather was also considerably warmer this time so cold starts would be easier on the engine I assume. Especially because the macroanalysis posted by BITOG uses the Ford 4.6L and the avg was only 3.3ppm for Al, Fe and Cu is lower then avg so that's good.
From what I've heard 4.6s have extremely low oil pump failures, as far as my engine specifically nothing has been touched on it, everything is stock and original.
The 4.6L 2v engines are very robust and reliable. But they can occasionally have issues with timing chain guides; indicated by elevated Fe and Al readings. Oil pumps are generally not an issue with these engines. This UOA isn't at a point of condemnation yet, but it's worthy of keeping an eye on those two elements. At the first audible sign of any slapping noise, or an increase in those metals, it's best to pull the cover and change the timing chain and guides.
Here is a link to my UOA data from my two 4.6L Grand Marquis from a few years back.
Post #42 (note - it's difficult to read because the old code from the BB format doesn't translate well into the XFO format BITOG now uses. You have to infer where the columns should be to understand the data)
Here is the crux of the info ...
10k mile UOAs with RK basic 5w-20 and 10k miles with Peak FS 5w-20. Neither the cheap RK oil nor the expensive full syn had a wear advantage; they were both WELL within "normal" statistical expectations. The wear rates were very low; less than 1ppm for Fe per 1k miles for both engines.
My point ... When the mod-motor 2v engines are in good operating condition, they should be very low wearing. The 2v engines are generally low stress and don't have a lot of problems. When you see Fe and Al escalating, it is nearly always the timing chain/guides. (The pump, cams, crank, rods, bearings, etc all are generally OK).
As I said, it's not time to panic for the OPs engine. Just monitor using consistent inputs. Don't add things into the oil in a lame attempt to assuage the issue; that will only confound the data. Stick with that oil and 5k mile OCIs and UOAs for now. Look to see if the wear rates change. If the Fe and Al go up in three successive UOAs, that's called a "trend" and indicates a problem is afoot.
The oil looks good - non GDI engine helps.
I'd be a bit concerned about the Al per what @dnewton3 said.
UOA's can be a great tool to detect unusual wear patterns.
One thing I've learned over the years here is that changing oil brands each OCI to see the difference in wear metals is a lost cause. To start, carryover of the previous oil will sometimes create confusing or unexpected results. And for the most part, engines will wear similarly regardless of oil brand.
I posted this picture in my C&P as well but it should be in here:
This looks like timing chain guide material to me, but I have never seen it before. It is interesting and good to know that even at 10k OCI the wear was still lower then mine. I will order some parts for it soon, I am likely going to use Melling, should I get the kit with or without sprockets?
I figured this was the case and that's good to know.
This is a prime example how a typical UOA is like trying to see the whole world by looking through a small drinking straw - UAOs like this can only see particles that are 5u and less. Even with crazy evidence of wear going on (lots of metal in the oil and filter), it really didn't up-tick the UOA wear metals ppm enough to raise a big red flag. See figure below - wear has to be pretty bad to get the ppm in the 5u and below range to have a pretty noticeable increase.
The UOA said "no abnormal findings" ... yet the oil drain pan and filter says a much different story. This is not an uncommon scenario in terms of the UOA insensitivity to anything above normal benign wear. If you had some long term UOA data in terms of ppm/1000 miles to track on this engine, you might have seen a very small up-tick in the wear metals over a few OCIs.
Almost with certainty, that is timing guide material in the photo. Sooner vs later is key; get the job done or it will continue to degrade and become catastrophic at some point in the near future.
I cannot tell you if the timing gears would need changed; that would depend on being there with you in the garage. Often, the wear on the chain/guides doesn't translate into the gears. But that's not a 100% certainty.
Perhaps order all the parts; have them on hand for the work day. Then if you need the gears, you'll have them, and if not, return them. It certainly cannot hurt anything but your wallet to change them out with everything else; if that is the comfort level you're at.
Yeah it’s the low compression oil rings they started using later on, direct injected and long oci that needs cleaning. Yours is built the proper way, wish I bought one when I had the chance. Lincoln town car, it was mint….enjoy the ride buddy.
