Valvoline R&P 5W-30, 4K OCI, 2025 Subaru Forester
Ya I'd most definitely at the very least run a 0w20 and skip the 0w16. Not interested in the lower threshold just to satisfy the companies CAFE credits.
With the Oil Temperature being 230 that you are seeing, do you know where the temp reading is taken from? I hope that oil temp is not being taken from the Oil Pan!
I know it’s not like for like, but the head temps on my Harley run 265 unless it’s crazy hot (95+ degrees) and I’m doing 80 on the interstate, then it’ll run at 285. If I hit stop and go traffic on the interstate in those temps, the heads will climb as high as 305 with the coolant cresting 225 (coolant only cools exhaust valve seats), so my oil is somewhere around 250+ regularly. I did 20k on HPL this last go around in those conditions regularly. I wouldn’t sweat oil temps in the 220s with a modern quality synthetic.
Most oil temp is taken from the pan or along the main galley near the filter, somewhere it'll remain submerged. An oil pan temp of 230°F is nothing to worry about. That's the upper end of what I aim for. (210-230°F) This is assuming you're using a half-decent synthetic oil that meets spec.
If the pan temp is 230°F, the bearing temp is likely ~260°F (typ. +30°F rise in commuter car) which isn't alarming. Note that using a higher grade will increase this temperature due to a combination of reduced flow across the bearing and increased hydrodynamic friction from the higher viscosity. (however slight) This increased temp could offset the higher grade in that the oil will thin down to the same viscosity as the OEM grade, just now at a higher temperature.
In either case, a better quality oil will give more peace of mind by way of less shear, better tolerance of fuel dilution, less foam/aeration concern, and better heat tolerance. Foam/aeration is a significant factor when it comes to heat as it can cause a substantial spike in oil temp. Given the higher heat capacity and thermal conductivity of PAO base oils, coupled with lower CoF targets, the oil is likely to run a little cooler (transfer heat better) on its own.
Wasn’t aware of that with the PAO base oils. Thanks for the info!
I don't like that KV100. Even when you factor the fuel dilution, it's still out of grade.
Otherwise, it's a good report for a new engine.
I'm guessing that a much thinner oil was used the first 1400 miles and that it wasn't all drained very well before the VRP was filled.
I don't think (yet) that VRP has a reputation for shearing really fast, so that's the only other explanation I can think of. Either that or it truly is shearing like mad.
I didn't account for the residual OEM oil being a 0W-16. That was my mistake.
The dilution aside, I wasn't suggesting VRP sheared a lot but rather that Blackstone's KV100 is wrong. (which it is at least half the time)
There are examples of VRP 5w30 holding viscosity on other UOAs. Initially, I too was concerned about shearing but having seen some good UOAs my concerns are mitigated.
Subaru FB25 oil temp sensor is after oil pump and before the oil filter on the front timing chain cover. Highest I've seen was 261 while towing. Winter temps 190-205 summer temps 210-240. 2018 Forester 6mt.
Thank you for posting this, Wintertime 5W-20 would be fine, but 5W-30 would be better. Summertime, kind of pushing it on 5W-30, but 5W-40 would be perfect.
For this application, OP is running a 5w30 where the manufacturer recommends 0w16. I would continue with this grade even if not oil type.
For the average Jane using what Jiffy Lube dumps in ‘cuz the cap calls for it, you’re telling us you don’t think an oil that loses viscosity on its own, toss in a little fuel dilution, and top it off with the fact that Jane not only ran the engine a quart low on oil AND ‘oops’, forgot her 6k interval but got it at 10k… isn’t going to matter to the engine?
No, I actually don't believe that makes a meaningful difference for the average ownership duration. While there may be some accelerated wear compared to someone who keeps the oil full and changes it on time, every 6k, using the specified 0W-16 -- I do not see this making a material difference in wear that will result in a wear-related issue.
By average ownership duration, are you referring to the average 3 year span someone owns a vehicle for off the showroom floor?
