Valvoline Multivehicle High Temp Grease
What is the general consensus on this grease? I would be using it for lubrication of automotive wheel bearings, ball joints, tie rod ends, and u-joints.
How does the Valvoline Multivehicle high temp grease perform compared to Mystik JT-6 High Temperature Grease? Is the Valvoline a stable, or does it have a tendency to separate out in the grease gun?
Mystik JT-6 Grease is about the same of what you are cross shopping. I would go with whatever is cheaper.
I have personally found that the grease gun design itself in combination with high ambient temperatures is typically to blame for leaking.
