Valvoline MaxLife or Castrol Transmax
Originally Posted By: ryanschillinger
Trans Tune isn't really an additive, but a solvent that helps clean varnish and stuff to keep from sticking valves. A lot of success stories. You add it and drive a while before changing the fluid and filter. Yeah, Camrys have a diff. It's weird, but true. I changed the fluid and filter, diff, and PS all with Maxlife and it worked very nicely. And it's cheap.
How would a Camry get around a corner with out a differential? On the I4s, at least up to 2001, there are drain and fill porst for the differential alone, not connected to the transmission. A transaxle does not take the place of a differential, it CONTAINS one.
Maxlife is selling for a good price at my local Wally, I may break my habit of SuperTech just to get a "synthetic"
Originally Posted By: slacktide_bitog
Originally Posted By: WyrTwister
Are you talking about this ?
http://www.walmart.com/ip/Valvoline-MaxL...Gallon/15125768
It is a full synthetic ? And rated Dexron III ?
Thanks ,
Wyr
God bless
It is probably rated Dexron III , but I see no indication it is Dexron VI ?
Where am I missing that ?
It is full synthetic ? I am also missing that in the add .
Thanks ,
Wyr
God bless
Yes, that's it. It's rated Dexron VI, which is fully backwards-compatible with Dexron III.
Thanks ,
Wyr
God bless
They changed the formula a couple years ago, but the stock photos aren't always updated at the same time.
If you go to the store and see it on the shelf, it will say full synthetic on the bottle, and Dexron VI on the back.
Maxlife ATF on Valvoline's site
Maxlife PDS says Dexron VI
Why not get the real Toyota ATF that came with your car new?
Go to dealer and get the real deal.
However out of the 2...
I hear good things about Valvoline MaxLife...
However I have never used it.
I have used Castrol IMV
however Castrol has a Pure Syn IMV also.
When you read about Max Life in the PDF read this
it should be! noted that
MaxLife ATF is not a OEM licensed product. The respective
vehicle manufacturers have neither evaluated nor
endorsed
MaxLife ATF in these applications.
If!an OEM licensed product is preferred we recommend Valvoline DEXRON® VI, Valvoline AT
F+4®!and!Valvoline MERCON®V for!the
corresponding applications
Thank you , :-)
God bless
Wyr
Thanks ,
Wyr
God bless
endorsed
How much is real Toyota ATF?
In response to the post by Eosyn, why not try some Seafoam Trans Tune before your next fluid change? I've read a lot of good reviews of it cleaning up sticky valves and whatnot, helping issues like you mentioned.
Cool, will look into it. Thanks for the recommendation.
endorsed
Im sure they have it on Amazon or go to a local Dealer and get the real deal.
Why buy the expensive Toyota fluid on a 15 year old car that would do great with a more readily available, less expensive option? I buy the power steering fluid for my Honda at the dealer because it takes special fluid, but maxlife does great in whatever I've tried it in so far. My Camry shifted very nicely cold or hot with maxlife. 13 Corolla has it in the trans and there haven't been any issues.
