PDS were updated 7.11.19.
I came across this article on the Valvoline website.
"Valvoline uses "proprietary" ashless anti-wear additives......"
"For MaxLifeâ„¢ oils, Valvoline employs a thicker version of the oil that still meets the requirements of 0W-20 because there is a broad range of viscosity that is acceptable within that rating, he said."
""It has more cleaning agents, more ashless antiwear, more added protection across the board," Smith said. The added turbocharger protection for modern engines also contributes to the oil's dexos 1 Gen 2 certification.
If all this sounds good, don't worry, you don't have to have a high mileage car to start using it. "There's no reason you can't use MaxLifeâ„¢ from day one," said Smith. "That's what I do."
