Going to be changing the front dif gear oil in my F150 (spec is 80w90, I will be using a 75w90 for improved cold weather viscosity since its almost only used in winter). Was initially going to use valvoline SynPower for a good price
erformance ratio but I saw Valvoline "high performance" 75w90 on the shelf next to it for a little more than half the price. Looking at the spec sheets I'm not sure what to make of it; The HP is MAGRINALLY thinner than the SP at 40 and 100C and shows a notably higher VI. Pour Point is notably lower on the SP but no brookfield -40C is listed... Not saying that the truck would realistically see the difference but isn't a higher VI generally an indicator of better base oils or does it just indicate the use of more VII?
High Performance: https://sharena21.springcm.com/Public/Do...12-ac162d889bd1
SynPower: https://sharena21.springcm.com/Public/Do...12-ac162d889bd1
