Valvoline engine stop leak
Probably something to cause a gasket or seal to swell, like High Mileage oil has, but more of it.
I would replace gaskets if possible, and if a seal is leaking maybe try and condition it with synthetic oil, Auto-Rx. It may get worse before it gets better if there was a false seal in front of the real seal. And if the seal is damaged or the shaft is damaged or rusty, etc, then nothing will help short of repair/replace.
Valvoline MaxLife™ ENGINE STOP LEAK & COND #VV344
DISTILLATES (PETROLEUM), HYDROTREATED HEAVY PARAFFINIC >=20- CALCIUM SULFONATE >=1.5- HYDROCARBON POLYMER >=1.5-<5%
Thanks.i dont have a leak but i just added a bottle of Valvoline engine stop leak.Car is 10 years old.
Huh??? I wouldn't use that as a "preventative" stop leak...not sure if you're using it for that purpose.
