I have read some various posts around the web stating that Valvoline DOT 3/4 Brake Fluid caused seal/hose degradation, especially in some older vehicles. I found nothing conclusive, but it does raise a concern. I thinking of running this in a '94 Dodge Stealth R/T w/o ABS which specs DOT3 or 4.
Not sure when this happened, but looks like Valvoline branded Brake fluid is no longer made by Valvoline. A company called Niteo Products owns the brand . Their sell sheet claims " Valvoline DOT 3 & 4 Brake Fluid is designed for natural rubber (NR), styrenebutadiene rubber (SBR), or and a diene (EPDM). Not sure if the formulation changed recently for better or worse. Anyone with experience running this fluid in an older vehicle?
