...my firm has found..
Question: Could using a 5w30, 10w30, 0w30 or even a 10W 40 or 20W 50, oil in my vehicle which specifies a 5w20 oil void my new car warranty?
Answer: Absolutely not. Vehicle manufacturers only recommend using motor oils meeting certain viscosity grades and American Petroleum Institute service requirements. Whether a motor oil is a 5W-20, 5w30, 10w30, 0W-30, 10W-40 or 20W-50 (for racing and high performance applications in, for example, a Cobra R Mustang) or even a synthetic vs. a petroleum based oil will not affect warranty coverage. The manufacturer is required by Federal Law to cover all equipment failures it would normally cover as long as the oil meets API service requirements and specifications and was not the cause of failure. In addition, the Federally mandated Magnuson - Moss Act states that a manufacturer may not require a specific brand or type of aftermarket product unless it is provided free of charge. If your dealership continues to tell you that you must use 5W-20 motor oil and or/ a specific brand of 5W-20 motor oil, then ask them to put it in writing. Their position is inaccurate, and, in fact violates existing law.*
Bottom line...use common sense and "a balanced attitude".
An energy saving 5w30 will offer more protection than a 0W-20 or 5W-20 and common sense is not so common...no lack of misinformation out there..
my usual .02
