Valvetrain wear...what Rat DOESN'T do...
In the bearings and other pressure points a straight wt oil protects better that a muliti visc oil all being the same add packages and viscosity.
Im not familiar with those graphs or the test details and methodology, but I will comment anyway.
IMO the FMEP is just a guesstimated number made up from what an engine should make in calculated power and what it does actually make. But the difference between actual output and calculated output actually has to do with a lot more than friction, and more to do with compression ring pack loading and windage loads, both of which are present in powered and unpowered operation (the test engine was run unpowered?).
I would also be interested what pressure the crankcase was run under, as the apparent HP increases as the crankcase vacuum increases with RPM.
Every engine, even two examples of the same engine, would have significantly different friction values as well as actual output values. But I would guess the graphed information was derived and calculated from a particular test engine.
Anyway, pretty interesting, but shouldn't be relied on for across the board application.
You omitted Volumetric Efficiency.
It's a crucial factor.
Steve:
Do you know of any place to get a 5.7 Hemi crate motor that is a value?
I have a truck that needs a new long block.
Jeff
Sorry I do not. My BIL runs a third generation high end machine shop, not known for bargains. If you know a dealer they can give you a hefty discount...
Naw, it don't take anything to open that valve against nitro
