Valve adjustment for 2001 Acura CL???
Lansing, MI U.S
Hello.
I drive a 2001 Acura CL which has 129k on it. The timing belt was replaced a year ago. I think it is the time to check the valve because the engine is not designed with self-adjusted valve system. What do you think about the job? Is it necessary even though I don't see any sympton yet?
Thanks.
I adjusted the valves on my Accord 4 cylinder last summer at approx. 90K. A few were a bit loose but nothing to worry about. It certainly can't hurt to do it but remember that too tight is worse than too loose.
I would have a friend who ride a motorcycle and works on his/her own bike engine help you with the valve adjustment. A DOHC with VTEC is not a Mitsubishi SOHC
If you're really concerned, I would pull the front bank valve cover and use some feelers in there. If they are out of spec, it would be worth buying a valve adjustment tool, basically a screwdriver inside a socket. But pray they aren't, since the rear bank will be a nightmare to adjust.
