Originally Posted By: Mykl
Originally Posted By: grampi
Plastic simply doesn't hold up...I've had the Hoovers, the Bissels, the Eurekas, and even the Dysons and they're all plastic...seems to me like they're purposely made to be replaced every several years...throw-aways if you will...you'll pay more for an Oreck, but we've had ours for 7 years now and it still works the same as it did new...
Okay, then here's a Dyson owner telling you that at least in regards to the Dyson, your concerns are unfounded. It is not a throw-away product and will last as long as you want it to. If anything, the way it is constructed makes it easier to service, disassembling it and putting it back together is as easy as building with Legos.
I am not saying that Dyson is better than Oreck, only saying that just because they are made of plastic does not mean that they won't hold up.
Actually it means exactly that...it's simple physics really...moving parts spinning in plastic mounts are going to wear out those mounts much faster than the same design mounted in metal...you are much less likely to find 20 or 30 year old plastic constructed vacuums still in use as compared to those made of metal...I will likely never have to replace my Oreck, and if I decide to, more than likely it will only be because I want something different, not because it needs to be replaced...
