UV dye harmful ?
IL
I had to bring in my 07 Silverado for a oil leak. The service dept. used the UV dye to locate the leak. I had just changed my oil about a month ago with AMSOIL Signature Series 0w30, so I do not really want to do another oil change. Is is safe to leave the existing oil in the engine with the dye?
It is only 1/4 of a ounce normally.
I would not think it would hurt but would not want to do a extended OCI with it. When we used it the max we ran it was 500 miles then changed oil.
The dye stays in the engine for a long time BTW. Take a UV light to the engine and next few OCi and you could still see traces of the dye.
In A/C units, it stayed it there. But not as severe as a engine.
Take care, bill
Bill-
How about with a transmission?
Chevy dealer added it to my transmission, when they were too stupid to figure out that the pan gasket was leaking.
Originally Posted By: MolaKule
UV leak detector dye will not reduce lubricant effectiveness.
Good enough! From the voice that I trust on such issues...
Originally Posted By: mrsilv04
Bill-
Would not worry about it then.
(sorry about the delay in responding, the board is not sending out updates to threads that you flag...)
Bill
Thanks for the reply. I feel better knowing that I am not doing any damage to my motor leaving the dye in the oil.
