Patman,
You have to go get s-e-r-i-o-u-s . . .
I, too have a well-worn copy of Bob Sikorskys DRIVE IT FOREVER (actually dates from around the 1978-1982 period; WELL worth having from a philosophical standpoint); and engine pre-warming is an interesting subject.
For some reason, I can't post links onto these posts, but I have about a half-dozen bookmarks on the subject. Search the TurboDieselRegister (TDR) via Google for good discussions (such as thread title, "Question for Arctic drivers")
Step One:
You want a WEBASTO or HYDRONIC gasoline-powered heater to install in the forward of the vehicle. Circulates coolant at predetermined temp, avoiding hot spots. (Also, instant heat and defrost ability as you get in). 24/7 timer set-up. Teaspoon of gas per hour.
Step Two:
You route the exhaust from the above through a sleeve encasing the oil pan.
Step Three:
An electric, stick-on pad set for both the trans pan and the differential.
Voila!
Get a THERMOCUBE automatic on/off plug at wall outlet receptacle that turns on Step Three heaters, and run plug wiring through to grille front.
Step Four
With a PRELUBER you'll have pressurized, hot oil throughout engine at start-up.
Overkill?
Made to order for this board!!
Step One:
Step Two:
Step Three:
Voila!
Step Four
Overkill?
