My son wants to give me his 1997 4Runner. I offered to buy it, but he wants to give it to me, so OK. It's been sitting in his driveway for about a year, during which time it's been started once or twice. I'm going today to do an overall evaluation, and see what needs to be done before I start driving it regularly. It's an SR5 with the 5VZ-E engine, two wheel drive. I'm in Southern California, temps at my house go from slightly below freezing (enough to get occasional frost in the winter) to about 105 F (during Santa Ana conditions), so not too extreme.
Owners manual says 10w30, Dexron II or III in the transmission, and 90w GL-5 gear oil in the differential. I don't think this one has the pushbutton locking diff, I'll check today. It also says ethylene glycol antifreeze, should I use the green universal stuff?
So. What fluids do you guys recommend? If the engine is dirty, I figured I would run Valvoline S&P to clean it up, otherwise maybe Supertech Synthetic unless something else is significantly better. I'd like to use a good transmission fluid, I was thinking Valvoline Synthetic or Mobil 1. Spark plugs? Just use the recommended Densos?
I'm hoping to get the maintenance records, my son says the previous owner was pretty meticulous, and then I can see what needs to happen.
Also, how often does this engine need a timing belt? I'm hoping there is a record of the last replacement.
