Ok BITOG-Kollective.....what say you? I know someone here is an expert...
When I go to the track, I use "the seatbelt trick" to keep myself more situated in my seat so I can focus on driving vs. bracing in higher G turns - using the inertial lock. You can see my process here:
This is the same procedure you use when you install a car seat in a car that doesn't have LATCH brackets. This is the same inertial lock that tightens your belt when you stab the brakes driving. So here, I am pre-engaging it. This is analagous to me driving, slamming on the brakes to avoid a crash and hitting a car - in that scenario the inertial lock will be engaged to keep you from moving before the crash. Many folks in the online track event world seem to think this is dangerous and defeats the car's safety system. I say that is not true. Many cars haver pyrotecnic pre-tensioners that fire when the air bags go to keep you even more situated. There seems to be a prevailing thought that you need to be able to move all over in the event of a crash or you will be injured (say in a rollover...you should read some of the comments! "You need to be able to move out of the way of the roof collapsing" etc.....that is exactly the opposite of what is safe, staying put is what keeps you safe in the research I've read. I reached out to the NTHSB as well as a known/trusted motorsport safety vendor. NTHSB had no data and was careful (duh!) of what they said but they didn't say it was dangerous. I reached out to VW - same. Motorsport safety guy said "no issue". Why would this be availalbe to you as a driver if doing it negated the entire safety system? The only reason your 3-pt belt allows movement is for comfort - for pure safety a harness would be the safest system. Then the folks will say you need a HANS or you'll snap your neck...I have had folks say that about this setup with the inertial lock. Craziness to me at least. What say you BIOTOG keyboard warriors?
