I've had no problems using Ford sized filters on Toyotas. Adds a little oil capacity and filter surface area for cooling. The FL1 and FL400 sized are good choices.
I'm thinking that the FL299(?) might actually hit a frame rail or suspension component if a motor/trans mount lets go. This will be for you to decide and measure.
You should NEVER mix threads regardless if you think it feels OK.
In reality, other than the OEM, there is no "SPEC" filter. All are simply supposedly backwords engineered. Why each brand uses differents specs makes you wonder how important it really is!
