If you're hunting for a better lube, you have a defective gun. I just use literally whatever, and everything runs fine
That has been my experience as well. However...If you're hunting for a better lube, you have a defective gun. I just use literally whatever, and everything runs fine
I'm sure that does work well.I've been mixing Mobil1 5w30 with Mobil1 Syn grease for a while now. It works well.
While you can of course use them separately - mixing the M1 oil + M1 grease together to form a honey like pour thickness makes for a great semi - auto pistol and AR lube .I've been mixing Mobil1 5w30 with Mobil1 Syn grease for a while now. It works well.
They were mixing a thick lube with a thin, high detergent lube to arrive at a medium viscosity lube with detergent in it. Motor oil is a medium viscosity lube with detergent in it.My brother used to shoot competition. Most of the guys he shot with used a mixture of STP and Marvel Mystery Oil. On their 45's at least.
I would have continued using gun oil if it was better. I tried motor oil and it was clearly better. So from then on I used motor oil. Being free was a bonus.You lost me at “slipperier”.
Look, guns aren’t that particular about the oil.
Also, it takes 5 drops to lubricate a Glock - so, that means that an ounce does about 100 guns.
So, compared with the 10,000+ rounds it takes to require that kind of lubrication, who cares about the cost of gun oil?
I would rather have a dedicated product for guns, personally, but your gun doesn’t care.
Nor does it know that motor oil is “slipperier”…if your gun doesn’t cycle reliably, you have a gun problem, not an oil problem.
I like Mobil One 15w40. I never tried 20w50 but I suspect it'd be good. Probably a straight 15W or 20W would be good too.I wonder how Valvoline Restore and Protect 10w40 will go at protecting against fouling?
I’ll save a bit when I finally buy some.
Yes, but STP is sticky, and would stay longer. Don't ask me about the tendency to hold dirt.They were mixing a thick lube with a thin, high detergent lube to arrive at a medium viscosity lube with detergent in it. Motor oil is a medium viscosity lube with detergent in it.
Either STP/Marvel or a grease/Marvel mix would work well. Motor oil also works well.
However, buying 2 things and mixing them is not economical or convenient.
Motor oil is free because you already have it for your car and 1/16 of a quart is enough for 1-2 years of shooting every weekend. Motor oil is convenient because there's nothing to mix.
I like 15W40 motor oil viscosity (the 15 number) because it's thick enough to stay put (even after shooting 100+ pistol rounds) until I'm ready to clean the gun. Then when I clean the gun, it wipes off easily and burnt powder residue easily wipes off with it. No solvent and no scrubbing required, except for Hoppys and a cleaning snake pulled through the barrel a few times. Cleanup is easy.Yes, but STP is sticky, and would stay longer. Don't ask me about the tendency to hold dirt.
I have used motor oil on my AR15s as they get to run quite hot ona Carfbine Course.
Handguns I stick with tradtional gunoils, that are thinner and smell nicer such as Remoil
