Carlostrece
$100 Site Donor 2025
I used to own several handguns and a couple rifles. My favorite was a Firestorm (made by Bersa). Bersa is in Argentina and Bersa handguns are very popular in South America and somewhat popular in USA. I used to belong to a Bersa/Firestorm forum.
I learned from South American gun owners that they typically use automotive motor oil for lubricating guns. As a USA gun owner, I was surprised, but I tried it.
I found that automotive motor oil was the best lubricant for guns that I ever used. It worked much better than official gun oils. Conventional motor oil would work, but I preferred synthetic motor oil.
Motor oil keeps the gun cleaner than gun oil does. Motor oil also seems to be slipperier. Also, if you use an appropriate viscosity of motor oil, it stays where you put it. Even recoil won't throw it off. It also is less messy because it doesn't run off.
I used 15w40 Mobil One and it was ideal for gun lube. Probably any 15w synthetic oil would be great. If you want thinner or thicker, then choose the viscosity you want.
1 qt of oil is more gun lube than I could ever use up for guns. So it's better and cheaper than official gun oils.
