Using leftovers
CT, YL of USSA aka Oceania
I have a neighbor who is planning to use his leftover 5w30 oil in a 2007 V6 Pontiac. The mix will be 2 qts of Valv AC (SL), 1 qt Pennzoil conventional (SL), 1 qt Chevron Sup (SM), and 3/4 qt of QS (SM).
Do you think he should do it? If so, should he run it in the summer or fall, and what OCI?
Thanks.
My only problem would be if the car asks for API SM...
If it states in the manual or on the oil cap SL/SM I'd take it to 5k or 6 mo.
Take care, bill
I agree with Bill. Check the oil requirement in the owners manual as I think SM is specified. If the owner insists on using the SL oil when SM is required then cut the OCI to 3,000 miles.
If it's not going to take him 5 years to use it up, sure. I wouldn't worry about it either way. I'd like to see the common passenger car engine that realized anything substantial (as in measurable) over one, properly spanned, OCI.
