Originally Posted By: fdcg27
Why do you want to do this?
Did you have some sort of engine problem that would have caused a rapid accumulation of deposits in the engine, like coolant leaking into the oil?
If not and if you've always run quality oils on reasonable drain intervals, then I think you can skip this step.
The oil you propose to use might be an authentic API SC oil in that it might really meet that long obsolete spec. It might also be real garbage.
One again, why do you want to do this?
If you must do it, you should at least use a decent 15w40 HDEO. Those are usually pretty cheap and you won't need a full sump anyway.
When I got the car it had done nearly 40k km's on bad oil mostly fake ones. I sorted the issue out by changing the oil in frequent intervals with genuine oils. But realized once I got the valve cover removed that it was all sheer black inside due to the abuse it had suffered. Naturally I want to reverse as much of it as possible, so opt for flushing agent in the oil before an oil change. This time I thought why not try flushing agent in current oil, remove replace with new filter and cheap oil+flushing agent, remove oil and replace oil filter before adding new oil. It seems 10 mins idling should be enough. Thank you guys for your responses
