Hi,
I may as well make the question short and simple.
A number of transmissions these days which are not equipped with dipsticks have special check or fill ports which are only accurate at specific temperature ranges. Is it considered acceptable to use an infrared thermometer on the transmission pan itself to determine if the fluid temperature is in the correct range for checking?
Thanks fellas.
Thanks fellas.
