quote:
Originally posted by Dave:
pgtr, you're missing one critical thing, at least in this particular case where we're discussing using a GL-4 in the transmission of a Subaru.
No I'm not missing that - my response was specific to Sprintman and his note on factory recomendations for
transmissions. Note the relevant quote included in my response.
quote:
Subarus share the front diff with the transmission.
That's the definition of a transaxle and and a different question altogether. Again, my response was specific to the quote I included. And yes, Subarus have been manufacturered that have either transaxles or traditional discrete transmissions and differentials.
quote:
Would you run a GL-4 in your rear-end?
I've already answered this elsewhere but again no, I would not run GL-4 in a differential nor would I recommend anybody do this. As folks should know, a GL4 can potentially ruin a differential gear set in short order. I thought I was speaking clearly to transmissions and not transaxles or differentialls but if not; my response was specific to the quote I provided and to transmissions,
not transaxles,
not differentials. Hope that helps clarify and one can never be clear enough w/ respect to GL4s
thanks,
PS: Just like I tend to take a critical view of manufacurer GL5 recomendations for a
transmission, when it comes to a manufacturer recomending a GL5 for a
transaxle, I would
also tend to differ from the manufacturer and consider exclusively focusing on the GL4/5 'combo' lubricants that a 'few' companies offer. I believe RoyalPurple was mentioned above - that being an example.
So to sum up, traditional/generic recomemndations (and these do have to be considered on a case by case basis and doesn't speak to units designed for ATFs or proprietary fluids etc...)
Manual Transmissions: GL4
Transaxles: GL4/5 'combos'
Differentials: GL5
Transfer Cases: ? (GL4, GL5, GL4/5) ?
Automatics: (subject unto itself - don't know a thing about it)
Again, these are only my general 'generic' start points I've followed and have to considered on a case by case basis and don't take into account many modern boxes designed for different fluids altogether outside the 'GL' realm.
