(USED) Wix 51522XP Cut Open
North Carolina
108in² of media. Almost exactly half the standard 51522.
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
[Linked Image]
Originally Posted by blupupher
What vehicle and mileage?
Also, is the backing material metal or plastic/nylon?
'03 911 Carrera. Filter was on for about 2k miles with Pennzoil Platinum 5W-40.
The backing is metal. A Lennox Gold cut through without much issue but I could not tear even a few strands - strong stuff.
Fram Ultra has a stainless steel screen. Boss has a polymer, or plastic. Can a rust test be done so as to identify the steel used in the mesh?
Originally Posted by rollinpete
That's a good looking filter,I didn't realize wix had a wire backing.
Thanks for the C&P
I think the WIX XP filters have wire backing. The standard WIX filters don't have a wire backing. Someone fix me if this is wrong.
Thanks for the C&P
This WIX flyer shows it as "wire backed" so sounds like it's metal mesh and not some bonded nylon like some use - ie, Purolator Boss.
http://www.wixfilters.com/wixxp/XPFlyer.pdf
