All you scientists out there need to try and answer this important contradiction. An appropriate answer here would unlock many important truths about engine wear and UOAs.
Buster just made an excellent post referencing this article: (http://www.practicingoilanalysis.com/article_detail.asp?articleid=401&relatedbookgroup=PowerGen
It says "For diesel and gasoline engines, there are a surprising number of laboratory and field studies that report the need to control particles below ten microns. One such study by GM concluded that, “controlling particles in the 3 to 10 micron range had the greatest impact on wear rates and that engine wear rates correlated directly to the dust concentration levels in the sump.”
Also "Much has been published about the risks associated with overextended oil drains and the buildup of carbon insolubles from combustion blow-by."
Now part of being a scientist/engineer is being able to mathematically visualize verbal formation and observations. If you buy the above quotes and the Jim Fitch article, then something should be obvious to those with a mathematics-science-engineering background.
If particulate debris causes most engine wear and we assume there is only a small amount of debris there after a fresh OC, then it should be obvious that the amount of engine wear should rise exponentially as the OCI progresses. Mathematically, this is a chain reaction scenario gentlemen!!!! Yes dudes, just like a nuclear fission reaction. In other words, at 5,000 miles, your amount of sump debris should be way way higher than it was at 1000 miles and if the debris causes the wear, then you should have way more wear from 5k to 6k miles than you would from 1k to 2k miles. In fact, if most wear truly comes from debris and there is almost no debris after a fresh oil change, then mathematically, there could easily be 50 to 200 times more wear going on between the 5-6k interval as there is during the 1-2k interval.
Now let's consider the myriad UOA's that this board seems to be obsessed with. They show no tendency whatsoever towards this kind of behavior. In fact, they may even show/suggest the opposite.....that wear may be lower from 5k to 6k than from 2k to 3k.
Now if somebody would like to come on here and explain this contradiction.............I believe many of us would be all ears. But don't anybody dare come on this board and be as illogical as to say that Jim Fitch's article and the UOA's jive.............that is nonsense.......there could not be a steeper or more extreme mathematical contradiction. I want some answers and maybe even some admissions!!!! Where are the scientists now? Where are the UOA experts........we deserve answers.
What's up dudes? Is Jim Fitch smoking the peace pipe or are UOA's ridiculously poor at quantifying engine wear? Does this statement from the article seem to suggest the latter is true as wear debris could end up still in the engine or the filter "hard particle contamination can agglomerate with soot and sludge to form adherent deposits between valves and guides". You be the judge!!!!
I'm out.........
1911.........The brainchild of John Moses Browning
I'm out.........
