I just got a used oil analysis pump (Amsoil model, pretty much identical to Blackstone's) and am a bit confused as to the best practices when using it.
My understanding is that I should measure the length of the dipstick for the tubing, mark it with a magic marker, then add about 6-8 inches to that length to reach from the dipstick tube to the pump. Then cut the end going into the engine at a 45 degree angle. Insert the angled end into the dipstick tube up to the mark, thread the other 6-8 inch end into the pump, attach the sample jar, and carefully pump up to the sample line.
But how many inches to the dipstick length measurement should I add to ensure I draw from the middle of the sump and not the bottom or the top?
Any other tips or suggestions on proper used oil analysis pump techniques would be greatly appreciated! Thank you!
