I've been lurking around this very informative site for a while now and thought I would post my UOA results on my wifes 2000 C230 Mercedes, from Blackstone Labs. This is a sample of Mobil 1 0W-40 with about 5k miles on it. This is my first post so hopefully I do this right. Any comments are very appreciated. Also a little about her car, it has 60k miles on it, 2.3L supercharged engine using a K&N air filter since new. She drives about 40 miles a day to and from work and it gets a lot of abuse from me when I get a chance to drive it.
Aluminum 2
Chromium 0
Iron 5
Copper 4
Lead 1
Tin 0
Moly 66
Nickel 0
Manganese 0
Silver 0
Titanium 0
Potassium 0
Boron 134
Silicon 3
Sodium 5
Calcium 2537
Magnesium 20
Phos 743
Zinc 876
Barium 0
TBN 5.8
SUS VIS @ 210'F 65.9
Flashpoint 360
Fuel .8
Insolubles .3
Here are Blackstones comments on this oil:
DALE: The universal averages column shows typical wear from this type of engine after about 4000
miles on the oil. Your oil was run 4950 miles, and wear levels read well below those averages. We
did find a little bit of fuel dilution, which is common in engines that see a lot of city driving and/or
idling. We don't consider it a problem until it reads above 2.0%. The TBN read 5.8, so this oil had
plenty of active additive remaining when you changed it out. The oil could have gone longer, and your
engine can take it, too! Try 5500 miles next time.
Aluminum 2
Chromium 0
Iron 5
Copper 4
Lead 1
Tin 0
Moly 66
Nickel 0
Manganese 0
Silver 0
Titanium 0
Potassium 0
Boron 134
Silicon 3
Sodium 5
Calcium 2537
Magnesium 20
Phos 743
Zinc 876
Barium 0
TBN 5.8
Flashpoint 360
Fuel .8
Insolubles .3
