Sent my used oil analysis to Blackstone this week. My truck has 52000 on the odometer and 2500 on the oil. Iron read 38 and fuel was 2%. Should I be concerned? All other metals were in spec. I use 5W-40 Rotella Synthetic with a Mobil 1 oil filter. I live in hot South Florida. I switched to Valvoline Cummins Premium blue 15w40 and will retest at 2500 miles on the oil.
I originally sent the oil in analysis because i thought the oil level was higher than normal. I have an H&S programmer on the truck, and use the truck for short trips a lot of times. Also, when i took the sample, I drove the truck only 5 min after being cold all night, but it did reach operating temp when i arrived home to take the sample. Not sure if it takes more driving to burn off residual fuel. I drained the oil and took the sample in the "middle" of the draining.
Jeff
Jeff
