Hello.
I noticed one, single drop of coolant on the ground when I changed my oil yesterday. I had originally assumed the water pump was starting to weep, but alas it's holding strong. Doing a little looking around, I found some puddled coolant on the drivers side, originating near/under the throttle, and dripping down from there. It's not landing anywhere hot enough to boil it off, and I'm not really sure what gaskets are in that area to begin the process of stopping the leak.
Picture 1 is a sensor directly below the throttle body, a few inches in from where the upper radiator hose meets the engine block.
Picture 2 is simply a lower puddle from above, just including as a just in case. I've already cleaned the area with some dawn power scrubber in hopes of better pinpointing the leak.
Anyway, those of you with knowledge of the 3100 V6, or with more knowledge than I, any ideas?
