hi, I have a 99 dodge neon, that I have rebuilt and modified. It has High compression, 11.5:1, and has some rhodes bleed down lifters.
I am looking for an oil like Mobil 1 0w-30, that will be as close to the same viscosity at start up, and normal operating temperature, as possible. I would also like to avoid having large amounts of polymers in the oil, because of the high compression. At one time I heard that full synthetic oils do not use polymers to modify the viscosity, is this true?
I am also fueling this with E85, I don't think I need anything special because of that right? the engine was just rebuilt, so there is no build up of deposits from gas too wash down in the oil. thank you
