Assuming the can volume is consistent with media area ..the difference would probably produce that difference in filter efficiency ..and it may not be the same media
Part Number: 51334 (26c.i.)
UPC Number: 765809513341
Principal Application: Acura (88-05), Chevrolet (85-88), Dodge (91-96), Ford (88-96), Honda (72-09), Hyundai (89-09), Isuzu (85-04), Kia (01-09), Mercury (87-91), Mitsubishi (89-98), Subaru (87-09) Atlas-Copco, Case, John Deere, Kobelco, Komatsu, Kubota, Onan, Toro & Yanmar Diesel, Other
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.194
Outer Diameter Top: 3.252
Outer Diameter Bottom: Closed
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=22/40
Burst Pressure-PSI: 280
Max Flow Rate: 9-11 GPM
Nominal Micron Rating: 19
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.475 2.173 0.233
Part Number: 51356 (19c.i.)
UPC Number: 765809513563
Principal Application: Acura (02-09), Chrysler Imports (92-06), Ford Probe (93-97), Honda (01-09), Infiniti/Nissan (96-09), Mazda (71-00), Mercury Villager (99-00), Mitsubishi (90-09), Saturn (04-07), Outboard Marine Engines, Various HD Equip.
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.402
Outer Diameter Top: 2.685
Beta Ratio: 2/20=6/19
Burst Pressure-PSI: 363
Gasket Diameters
Here I assume the same media ..with an expected reduction in rate of return as you go bigger. Eventually you have quite a few more large pores in the distribution.
Part Number: 51348
UPC Number: 765809513488
Principal Application: Various Chrysler/Jeep (82-09), Various GM, Saturn (85-07), Lexus (90-09), Saab (67-09), Suzuki (86-02), Toyota (88-09), Ford (03-09), Mazda, Mercury (05-09), Yugo (86-89), Harley-Davidson, Various Lawn&Garden, Farm Equip.
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.404
Outer Diameter Top: 2.921
Thread Size: 3/4-16
Beta Ratio: 2/20=21/37
Burst Pressure-PSI: 275
Max Flow Rate: 7-9 GPM
Gasket Diameters
Attached 2.734 2.430 0.226
Part Number: 51516
UPC Number: 765809515161
Principal Application: Ford/Lincoln/Mercury (81-09), Chrysler/Jeep/Mitsubishi (02-09), Mazda Trucks (94-07)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.828
Thread Size: 3/4-16
Beta Ratio: 2/20=14/31
Nominal Micron Rating: 20
Part Number: 51068
UPC Number: 765809510685
Principal Application: Agco Tractors, Chrysler (70-91), Ford/Mercury (83-97), Kubota Engines, Land Rover (95-04), Toyota (68-90)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.338
Outer Diameter Top: 3.660
Thread Size: 3/4-16
Beta Ratio: 2/20=10/26
Gasket Diameters
Attached 2.834 2.462 0.200
Part Number: 51515
UPC Number: 765809515154
Principal Application: Chrysler Family of Cars/Trucks (57-70), Ford Family of Cars/Trucks (57-00), Mazda Trucks (94-00), Toyota Landcruiser (71-96) - (Two Quart version is 51773)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.178
Outer Diameter: 3.660
Thread Size: 3/4-16
Beta Ratio: 2/20=13/23
Burst Pressure-PSI: 290
Gasket Diameters
Gasket Diameters
