Undercoating Gun
Toronto, Canada
https://www.princessauto.com/en/detail/paint-spray-gun-only/A-p8006583e
This gun has a 2mm nozzle. Will this gun work with thick dripless rustproofing? I have been using a suction feed gun and find that I cannot get enough volume of flow. So it takes a long time to spray a truck. I have come to the conclusion that to speed up the process I need a pressure fed gun.
The pressure pot I am thinking of using is this 10l pot
https://www.princessauto.com/en/detail/10-litre-paint-tank/A-p8006581e
I will also need to use a spray hose. Can a hose be attached to the outlet of the above gun?
Thanks, Trav. I just called Pro-tek. Price for the 7535-UG gun is $321.75. Price on the gun + 5 wands 7535-UGK is $598.49. Very expensive.
https://www.pro-teksprayequipment.com/prod/293/kit-gun-rods.html
I know you have been recommending the Eastwood gun. At US $199, it is somewhat expensive for me with the exchange rate, shipping and customs fees. It will be close to $400 Cdn to bring it in, so I was looking for a less expensive option. But the Pro-tek isn't it.
Between the Eastwood and the Pro-tek, would one be superior to the other?
That is a siphon fed gun and I have a gun similar to it. It works well with the thin drippy undercoating but does not produce enough volume of flow with the thick dripless undercoating to cover large areas in a reasonable amount of time. Hence my search for a pressure fed gun.
This is the gun I am currently using
https://www.dominionsureseal.com/product/european-made-adjustable-spray-schutz-gun-bupa/
Just checked the price on this gun
https://www.dominionsureseal.com/product/001735-complete-rustproofing-kit-2-25gl-ass512eq/
I was quoted $1279 by Napa !
I have the top of the line Eastwood gun with the wands and it works very well. Too bad about the exchange rate, that really stings.
For rustproofing I use a gun that is pressure-fed, and made to spray thick material.
You could also look into a schutz gun.
The Dominion Sure Seal gun I have, which I linked to in a previous post, is a Schutz gun and it does not provide enough volume with thick materials.
I use the one Eastwood sells and have had no trouble with it, it does a nice job. If I were doing big trucks then the other with the 2.5 gallon is the way to go.
Fluid film has a gun with wands that is much cheaper and will do the job fine its not a heavy duty and wont last as long but if you are only using it a couple of times a year its good enough. Look at Amazon or ebay Canada.
