I know a few people on here are pretty well versed with this unit, although my question in general is not specific to Ultragauge.
I've been watching short and long term fuel trims for a few weeks now. What I've observed at several RPM's is that at idle, LTFT runs about -3 to -4%, at 1500 RPM's LTFT sits at 0%, and at 2000 RPM it is about +4%. I'm not sure whether those numbers are acceptable or they should be telling me something. I understand what they represent and how they are calculated but not whether leaning out at idle and enriching at 2000 RPM's by that margin means anything. EDIT: I don't mean to say I completely understand fuel trim tables and how many there are/what speeds/etc but rather that it takes O2, MAF, etc. sensor data to determine fuel trim.
Under long deceleration (say down a hill coasting) the LTFT will go to -7 to sometimes as much as -10%. The question is, is Ultragauge only pulling raw fuel trim data from the ECU or is it interpreting the data in some way? I ask because I'm never quite sure whether the fuel cut-off threshold has been properly set, and curious if Ultragauge does not think that fuel cut-off has been reached but the ECU has cut off delivery, would Ultragauge report an erroneous negative LTFT, thinking that fuel cut-off WAS actually an overly rich event being compensated for?
Thanks in advance and hopefully I am being clear.
