UA80E / UA80F - Toyota/Lexus Direct shift 8 Speed
Originally Posted by robd
Thanks,I'll keep everyone posted.
I'd be interested in hearing to see if it was a bad batch of transmissions or it is something that doesn't appear until later.
Hopefully just a learning curve and the bugs were worked out. There were some updates and I'm hoping now with this transaxle being out for over two years and a lot of overall accumulated miles it should be fairly reliable. I'm also wondering if now with 8 gears, a transmission is naturally going to shift more and hunt more than a five or six speed gear box accelerating or decelerating to the same speed. Add to that multiple lockup's of the torque converter clutch through several gears may take getting use to. All prices paid to get better efficiency. Smoothest gear transmission I ever had was a 1965 Impala with a two speed powerglide transmission. Shifted only once and no lock up torque converter. Only a properly operating cvt is smoother.
Any chance do you have an image of transmission thermostat located just under the radiator for the UA80E Transmission?
Thanks ....very helpful information.
I might have this at home as I printed off a bunch of information when I had the Highlander. Let me have a look when I get off the road today.
Edit: Although if you look under the front below the radiator there is a square hole in the black plastic splash shield where it is on the drivers side.
I suspect this unit is the same unit that Volvo use in their 8 speed applications.
I'd love to know if Toyota use the same 6 speed that's in my V40 (Aisin Warner TF71-SC) as information is very thin on the ground and I want to change out the oil at 20-25k.
Originally Posted by irad
Could you just put in as much as what drained out?
If you drained it cold and refilled with the same amount of fresh, cold ATF, I don't see how you could possibly change the level from where you started, but I guess I get people's concerns here.
Toyota certainly doesn't make the 'by the book' process easy.
From the OP's initial post it seems you could if you used the exact same fluid and not universal ATF.
The UA80E (2wd) / UA80F (AWD/4WD) found in later RX-350's and Toyota Highlanders is an 8 speed multi-lock-up transmission and it's considered "Sealed for life" with no serviceable filter and no dip stick. Just a tad over 8 quarts is required to do a full exchange and just over 3 quarts to to do just whats in the pan (if it had one).
The transmission is emptied by taking out the #10 Hex bolt on the bottom of the transmission. Some fluid comes out and then you need a #6 long Hex to take out the plastic straw located inside the same hole to release the remaining fluid from the bottom of the transmission.
It comes filled with Toyota WS fluid by default which can run at 200F regularly not towing. The only time they recommend a change is in Severe duty situation which then it should be changed at 100,000 miles (160,000km) - Yeah like that was going to happen.
Once you have drained all the fluid you put the straw back in the drain hole just hand tight. Then fill the transmission using the WS bolt plug on the side of the transmission located behind a cover inside the drivers wheel well. This small cover is moved out of the way by removing the 2 bolts (10mm). It will take about 3 quarts. Fill until it spills out of the hole in the bottom where the straw is.
You also need to press on the end of the transmission thermostat located just under the radiator. There is a hole in the skid shield. Press on the end of it with a flat screw driver and then insert a small pin to lock it in the open position. This is necessary as the external cooler is only open to the ATF fluid cooling circuit when the fluid is at higher temperatures. It is necessary to make sure the external cooler is also full of fluid when correctly refilling the transmission as per Toyota Tech Info procedures.
Start the vehicle and put it in Drive with your foot on the brake for 10 seconds, then reverse for 10 seconds to fill the circuits with fluid. Then back in park. Then fill the transmission further until it spills out the straw again with the vehicle running still. Then with your scantool or Scangauge II with 4.42 software or higher and X-Gauge code for the Transmission Pan temperature. Wait until the fluid reaches 104F and reinstall the drain plug. Your transmission is now full to the correct level. Do not exceed 113F before putting the plug back in the bottom of the transmission or it will be under full. This temperature changes rather quickly in hot weather so be quick about it.
This is has to be done with the body of the vehicle level off the ground so you will need jack stands for the rear and front of the vehicle to do it properly. It's also best to do it when the vehicle is cold because it will quickly heat the transmission fluid back up over the 104F really quickly thanks to the coolant to ATF heat exchanger.
Simply removing fluid from the pan and pouring the exact same amount of fluid back into the transmission can have undesired consequences due to fluid expansion rates differing from Toyota WS official fluid and some other brand that meets this specification which is why it's best to fill and check using the procedure above. Toyota advises always using this method for refilling the transmission anyway.
If anyone has this transmission and has questions about this change procedure feel free to send me a PM.
I will tell you after having done this today on my UA80F transmission the Toyota WS fluid leaves a lot to be desired in terms of shift quality and I would highly advise using some other brand that meets the WS fluid specification. I chose Amsoil Fuel Efficient Vehicle formula which is meant to replace WS fluid, because I'm a fan of their transmission oils and have used them in the past with excellent results but there may be other quality manufacturers out there just as good.
Sorry I didn't think to take pictures of the process but when I drain/refill again I will take pictures.
I needed: Washer Planetary Ca - 35738-48050 - For Toyota Transmission UA80F; UA80E
Advise someone where to buy new or used, or does anyone have this transmission in parts and sell this part to me, or where it can be made or restored (if possible)
Wow. This thread is one of the most informative I've ever read on the internet!
I'm a big Toyota fan, it's the only make we have.
We traded a 2011 Sequoia in for a new 2019 Highlander LE Plus in September 2019. Yes, looking back, I wish I had not made that decision but it's all worked out to the good. Neither me nor my wife was ever 100% happy with the Highlander, it was her daily driver and she didn't have many complaints outside the HORRIBLE transmission.
You would make a turn, say from one road to another under speed. While coasting through 3/4 of the turn and then getting back in the accelerator, it suddenly felt like the engine was fully retarded or you'd just been hooked up to an aircraft carrier. There was NO acceleration for 1-2 seconds. The vehicle simply would not accelerate but continue to slow, then.....wham! It would suddenly start speeding up, all the while your foot was getting deeper into the throttle.
Other than that and it was kinda tight side to side for me and front to back, it DID ride extremely smoooooth, got great fuel mileage, seemed to be easy on oil, tires wore extremely even, decent visibility and would carry 4 decent-sized adults comfortably.
I hated paying for the lane keep assist when we turned it off permanently before we left the dealer, always turned radar cruise off, hated the auto start-stop. You have to pay for these things, whether you want them or not. But.....thanks to the idiocy of 2021, Carvana paid me within $215 of what we paid for it new, so it's someone else's problem now. I am now the proud owner of a vehicle I have longed for for many years - an LX570. A real SUV with a real engine and transmission.
Anyway, wanted to share my horrible experience with the ridiculous 8-speed transmission and it's programming. Never again. I also want to thank the OP for the TIS link and while I never plan on owning an 8-speed trans again, that fluid maintenance write-up was the best I've ever seen about any Toyota trans. I'm a huge believer in maintenancing the transmissions, no matter what some service advisor or manufacturer says.
I do change the transmission fluid in my Toyotas (and filter/gaskets) - both 5.7L/6-speed chassis and the 2015 RX350. I use the Amsoil OE fluid and have not had any problems. Yes, I use something else other than Toyota WS OEM fluid in my LX570, my Tundra and RX350. I do use OEM filters/gaskets in the Tundra and LX, I've been using a Napa filter/gasket kit in my RX350.
I have no record of the transmission fluid being changed in my RX350 until I did it at 165k miles shortly after I bought it. I dropped the pan, cleaned it and the magnets, changed the filter and gasket and refilled. A week later I did a spill-n-fill and I plan on dropping the pan again in the next few weeks to clean the pan/magnets, replace the filter and gasket again. I think it will be good for 100k miles or so from then.
I also have no record of the fluid being serviced in the LX until I bought it at 109k miles. I dropped the pan, cleaned it and the magnets. Fluid looked good, not too much swarf on the magnets. I didn't change the filter because I want to do a couple of drain and fills, then drop the pan again, change the filter and refill. I first changed the fluid in my Tundra at 65k miles, then a shop did a drain and fill at 130k. I plan on doing a couple of drain and fills and then a pan drop and filter replacement soon.
I know this is an old ticket. I was able to get it done on our 2017 Sienna last week. Thank you all for the instructions and tips shared!
Long story if you are interested…
I have been attempting to do it myself for a while. The jerky 2-3 or 3-4 gear shift was getting worse on cold days in the past years. There is a Toyota Customer Support Program on certain UA80 (only by trans serial number, not by VIN!!!) to address a manufacturing defect during certain period that may potentially cause bigger issues down the road. The program extends warranty on the affected trans to 10 years and will replace whole trans if certain symptoms are actively present at authorized dealer. Although we have not had such symptoms yet, I have been trying to locate our trans serial number sticker multiple times as a precaution but with no success. And I was concerned touching the trans myself like changing fluid would void the extended warranty.
Until last month we had to change the battery (yes, original battery lasted for about 7 years), I found the trans serial number sticker is finally visible with battery removed, which ironically confirmed our trans is NOT covered by the 10-year warranty (not sure if I should take it as a good or bad thing… I don't want a trans that would potentially blow up anytime, but I would be very happy to have a new trans for free…haha). I then decided to do it!
At 80K miles this was first-time transmission fluid change. We drained out a little bit less than 3qt, filled in 3.5qt Valvoline Maxlife, and adjusted fluid level following the jumper wire method.
The shift is much improved. I plan to do another drain and fill next month.
Thanks!
Update: So it has been many thousands of miles since the ATF change and it appears that the transmission has compensated for the new ATF with it's adaptive logic and the not so great low speed shifting has returned. It's jerky and abrupt at times and like it can't make up it's mind what gear to be in. Especially between 1st and 2nd gear when re-accelerating from slowing down or taking a corner at slower speeds without stopping first. Downshifts on the highway are also felt some of the time almost like there is a broken/worn engine mount.
Steve
I have a 2019 RX 350 and I do a lot of engine braking down hills and coming off the highway and I'd say 70% of the time if I just move the shifter to sport causing a downshift from 8 to 6, it does it with an abrupt and harsh clank. If I put it back into drive and repeat the process, it won't do it the second time. I also agree this transmission is manic in lower gears being too quick to both upshift and downshift. I also have a driveline shutter while in park that goes away when you out it in drive - I've driven several RXs and they all exhibited this quirk. Overall, I've never been a fan of this automatic.
I'm just about to have the dealership do a transmission fluid change at 60k miles because the goal is to keep this as long as possible and I just don't believe in lifetime fluids.
I have no complaints with the UA80E in the Highlander.
The only thing I had to get used to is the 4-3 (or maybe it's the 3-2) downshift when on the brake (while in D range). There's engine braking before the downshift. When the downshift occurs, there's what feels like an abrupt loss of engine braking, as if the transmission goes into neutral.
I haven't looked for specifics, but I think it's due to a large gap in ratio between the two gears.
Don’t think this ever answered. Does anyone know if UA80E transmission in the 2020 Lexus ES350 has the bypass thermostat?
Thanks for the tech write up.
I am about to service our 2013 GS350 F Sport with 60K miles.
I bought 6 quarts Idemitsu WS equivalent, which is Synthetic.
Guess I am a little curious about the thermostat; not sure if it applies in a 2013.
The 2013 uses the 6 speed; the 8 speed was used in 2014 forward except on AWD cars, if I am not mistaken.
I will see what I can see.
Thanks again.
When I worked for a Lexus dealership only the rwd versions of the vehicle like the rc350 got the 8-Speed automatic. The awd were always the 6 speed automatic. Nobody was able to tell me why Toyota/Lexus did this. Being in Colorado we only had two base model rc300's that were rwd and sat for a year until a Florida dealership wanted them.
2013 was the 1st year of the GS refresh; they all got the 6 speed. Later, maybe 2014, the RWD got the 8 speed but the AWD cars kept the 6 speed. Perhaps it was better fitment? Dunno. It's been said the 8 speed tends to hunt for the right gear at times. The GS is a wonderful car, but sucks the gas.
According to Repair Manual (TIS subscription) I see no reference to a thermostatically controlled ATF cooler bypass for my 2020 Lexus ES350 with the 8 speed UA80E transmission. The cooler is located under the battery. ATF inlet and outlet hoses run directly between cooler and transmission body.
Maybe the bypass is on the coolant side…I will look later. But, if on the coolant side, why would that be relevant to setting the ATF level?
Too bad about these 8 speeds. I think the older 6 speed had a great reputation and the ones I've had with it have shifted very well and decisively. More is not always better
I had a 2013 it was great. Drove a couple with the 8 speed and didn't like it as much.
