Can't figure out how to post a jpeg to this forum, but I just completed an experiment re-using an oil filter after an oil change. The wear metal figures etc were all constant over the last 3 10K km oil changes, but the insolubles figures did vary as follows:
After 1st oil & filter change: 0.4%
2nd oil & filter change: 0.5%
3rd oil only change: 0.4% (Surprise figure)
This means the oil filter did a slightly better job when used a second time from 10 to 20K km (The UOA wear metals for the 2nd and 3rd UOA were identical).
The max limit is 0.8%, so I have extended the oil filter change interval to 25K km (The recommended max oil filter change interval is 20K km), so I will be exceeding the OEM limit by 5K km. To match the new filter change interval I have extended the OCI to 12.5K km, so I will continue with the two for one schedule for a while.
Note: The engine holds 5.6 liters of oil and the filter 0.9 liters (I did not try and drain it), so if you allow for the contamination of the new oil, the oil filter did a real good job during the second phase use.
