Turtle Wax Platinum Spray Tire Shine(CAN)
NC
I Like to use tire shine but most all that I try leave my cars with splatter all over the side. UN-TILL NOW. I used the Platinum last night and I like the control of the spray and one coat leaves a great coverage. Drove to work and no splatter on the body or wheel wells.
Typically if you let it sit it shouldnt fling. I usually apply it and let it dry. Not always possible tho. I have to say i still occasionally use tire shine but ive kind of moved away from tire shines. The high gloss tends to look cheap. Weird because i used to really like it. Now i just clean my tires.
Stoner's More Shine Less Time works very well. Plus others rave about it also. Around $4 at Walmart iirc. Never had it fling and don't recall anyone reporting it. Lasts awhile and tires don't turn brown afterwards which is one of my biggest pet peeves.
I used to use the Stoner spray can and it was good but I still got some fling the following day
If you had sling after using More Shine you used too much. I have never had it sling and used it on hundreds of cars.
Sounds like the Turtle Wax product deserves a trial.
Another cause for sling is using the wrong application tool. Squirting it onto a rag or paper towel doesn't allow it to spread very evenly. I recommend a foam applicator, specifically a curved one for tires.
Yeah but it waterproofed my driveway
I quit using it!
