Traction control turns off, stability control generally does not.Most of those buttons are placebos that don't really turn it off
I’m stealing this line.There are times where a spinning tire is better than one that won't spin. Examples include avoiding getting stuck in gravel, sand, mud or snow or any combination of those on a tricky hill. Another reason to turn traction control off on a Mustang (or similar) is to engage in direct population control measures.
We're already having a constructive discussion, and I'm learning more than I did when using the search engines.Hey @Shel_B , how about if you google it and tell us what kind of information you find?!?
Then we can have a constructive conversation from there.
I'll see if I can find more about that for my Camry. Thanks!That's for when you need to do a burnout, of course!!
Also, my 2018 Corolla manual says to turn it off when you're stuck in mud or snow and need to rock the car to get free. VSC can be turned off, too, by holding the button 3 seconds. That turns off TC and VSC, and also disables automatic braking if you have it. There's no mention of ABS being affected.
Oh, no no no.We're already having a constructive discussion, and I'm learning more than I did when using the search engines.
If you use a search engine, you'll find out what I learned and maybe you'll discover that what's happening here gives a fuller and more complete picture of the subject. Thanks for jumping in with your valuable and constructive suggestion.
I recently discovered that I can turn the traction control off on my Camry. What benefit might there be from doing so? Is TC tied into the anti-lock brakes? Thanks!
Thanks! It works in a similar manner for my Camry.I'll see if I can find more about that for my Camry. Thanks!VSC can be turned off, too, by holding the button 3 seconds. That turns off TC and VSC, and also disables automatic braking if you have it. There's no mention of ABS being affected.
Yep, that's exactly it for your Camry. Turning it off can be helpful if you're stuck in the snow and needing to "gun" your way out.Thanks! It works in a similar manner for my Camry.
