Symptoms: right side
1 Random...very random 16 times good/1 with issue....2 good/2 with issue..etc
2 Fast blinking signal
3. Saw the turn signal "glow" green the other night just cruising
4 Replaced all 4 right turn signal bulbs
5 Happens whether headlights are on or off
6. I noticed when the front outer running light wouldn't light=fast blinker issues..When it was lit, all was good
7 Tested the "harness socket" it got normal continious power..even with the fast blink issue..the outer socket gets good normal power...put bulb back in and it goes fast blinking
8 I swapped the "outer" sockets from left to right...Used blinker 8 times = normal for now
Guys at the part store..even customers ALL said turn signal switch...If that was the case, why would it go from normal to spazen just taking the socket out of the headlight??? Switch wasn't being altered.
Could the outer socket just have had poor contact??
What else???
Dusty
What else???
Dusty
