- Joined
- Oct 28, 2014
- Messages
- 1,187
I got a response from [email protected] in regard to reverse bleeding, which is NOT advisable on vehicles with ABS: https://www.brakebleeder.com/preventing-damage-abs-modulators-brake-pad-replacement/ Since this company also sells reverse bleeders, I sent them the email referenced in post #37 above. I received the following:
Thanks for pointing this out. The article is correct. When bleeding brakes you should always begin with new brake fluid. You can use the Phoenix Reverse bleeder as a vacuum bleeder and exchange the fluid from the top down. Once clear brake fluid is flowing you can then proceed to reverse bleed.
Air normally only gets trapped inside a brake system when replacing a brake part. When any brake part is changed the brake fluid should also be changed as old brake fluid can corrode a new part faster than an old part.
Jeremiah Terry
Phoenix Systems LLC
P. 435.216.1879 M. 435.862.1571 F. 435.673.0222
1076 East Commerce Dr Suite 400
St. George, UT 84790
[email protected]
In simple terms, ABS Modulators DO have non-serviceable filters [BTW, I first heard this from Trav], and should not be reverse bled (unless bleeding from the "top down" is accomplished first) but why bleed both ways? This means that the brake bleeding procedure I spelled out in post #35 above is correct.
Jeremiah Terry
Phoenix Systems LLC
[email protected]
