ULVER - IMO, Fleetguard are fantastic filters. I have been using them exclusivly for about 3 years. I even have experience with the LF-3554 which I am currently using in a 3.4L GM and my boat with the 4.3L as well.
Here are some spec's I got from Fleetguard a while back. Not sure what they all mean, but I liked the the fact that the LF-3554 has better filtration but still flows twice as much as the LF-782.
LF-3554
CAPACITY 14 g SAE J1858
10 MICRON EFFICIENCY, TWA 73 % SAE J1858
30 MICRON EFFICIENCY, TWA 100 % SAE J1858
CLEAN ELEMENT DP, MAX 3.48 PSI ISO 4548-1
TERMINAL DP 7.98 PSI
RATED FLOW 7.93 GPM
ELEMENT COLLAPSE/BURST, MIN 79.77 PSI ISO 4548-3
HYDROSTATIC BURST, MIN 203.05 PSI ISO 4548-6
HYDR.PULSE DURABILITY, MIN 60000 Cycles ISO 4548-5
AT HIGH PRESSURE 72.52 PSI
AT FREQUENCY1.5 Hz
VIBRATION FATIGUE, MIN 10000000 Cycles ISO 4548-7
AT ACCELERATION 5.1 G's
HIGH TEMP 250 F°
LOW TEMP -45 F°
ADBV LEAKAGE, MAX 60 mL/h
Compared to the same filter with their regular media (LF782)
CAPACITY 10 g SAE J1858
30 MICRON EFFICIENCY, TWA 76 % SAE J1858
CLEAN ELEMENT DP, MAX 4.06 PSI ISO 4548-1
RATED FLOW 2.91 GPM
HYDR. PULSE DURABILITY, MIN 60000 CyclesISO 4548-5
AT FREQUENCY 1.5 Hz
HIGH TEMP 250 F°
LOW TEMP -45 F°
FGD 2.2.7
