I believe he is saying while the engine is cold then boost would be harder on it than a comparable N/A engine.
Once warmed up it becomes moot, but everyone knows that the more power produced per cubic inch the more likely you are to wear it out sooner. That doesn't mean turbo motors suddenly explode, just that an equivalent design N/A would likely last a little longer under the exact same duty cycle.
Many modern turbos do not allow full boost when cold, and modern engine controls help hold them together in the real world better now. But there was a time when forced induction meant short life.
Cujet, the temp spec you quoted was seen by me in the 60's in an HP Books publication which credited Ford for the research. But since it was done with old motors on old dino oils it may not be as applicable today.
