a few years ago, a john deere mechanic told me the same. all hydro transmissions make noise, just the nature of the beastAll Hydro transmissions make sound, get used to it.
My old 1998 TT K61 i bought new is still going strong entering its 28th year. No hour meter but I’d guess it’s near 2,500 hours and many hours pulling a plugger, lawn cart, and a heavy Cyclone Rake in the fall. I’ve changed the hydro oil about every 500 hours estimated and have used Mobil1 15w50 exclusively. It’s always been a bit noisy but I feel it’s just the nature of the beast. If this little JD LX188 explodes in a ball of fire today my only complaint would be that 1998 was the last year of this model. It owes me nothing!I changed the oil in my K46 last spring at 585 hours, most likely it had never been done before and had gotten a pretty loud whine over the years. I used Mobil 1 15W-50 which quieted the unit to a large degree but didn't eliminate the sound. The mower currently sits at 614 hours. Not all the old oil drained out(it calls for 2.3 quarts- I was able to get right about 2 quarts to drain). Those last couple ounces of old fluid won't make a difference but this BITOG after all
Would it make sense to do another drain and fill now with only 29 hours on the new stuff? I want to make sure all the old fluid gets replaced but it's really a hassle to pull the gearbox from the mower.
John Deere HyGard LV (low viscosity) should be the about the same price as engine oil but much better anti-wear, excellent flow and GL4 rated. If you're in a hot climate then I would try the heavier HyGard which is closer to an SAE 40/50. Hydrostat transaxles need a gear oil with good flow. The noise you're hearing is either from wear or cavitation of the fluid (poor flow).My experience mirrored yours. Not sure when I first changed mine (Deere L110) but it would have been similar hours - I used 15w50 too as that's what the reading suggested. After 2 changes it was still noisy, but quieter than it was prior to changing. Well it came time to sell it and I wanted it to be "right" so I serviced it again, this time using some leftover Mystik hydraulic oil (I forget the exact product) and this time the thing was darn near silent! I had an old fellow bring me his L110 for a bunch of repairs and while it was there, I thought that I'd service it too. Same deal, used the "correct" 15w50 and it was noisy. Same deal with the ZT2800s in my zero - I used Amsoil Hydro 20w50 and it's (a bit) talkative as well. Between my anecdotal experiences and talking with another forum member, I've decided that I'm going to use a dedicated hydraulic oil. The heaviest that I could easily find was an ISO100, which is heavier than the Mystik in a 5 gallon pail so that's where I'm going to start.
Getting to fill plug to extract requires deck drop, center chute removal, reservoir, pulley and fan. Not hard, annoying.
Fan was clean, tranny was clean. I don't cut when wet but do get some dirt that sits on tranny. The top of reservoir had more dirt than the tranny/fins. I used a small flat tip just to knock it loose and vacuum so I could work on it. I do normally take my leaf blower and try to blow everywhere through cracks etc. The deck gets a lot of build up on top so always blowing it off each use.Good work! Not that it looks horrible under there, but I see some dirt buildup. How did the cooling fins on the transaxle look? I've seen them so hopelessly clogged with debris that the cooling fan can't do it's job and you'll get overheating, loss of speed, etc.
I ordered High Performance Lubricants HST20W50-Q Hydrostatic Synthetic Transmission Fluid. There are some threads where members had used HPL. I actually just called HPL back and they are switching it to HST 5W-50 Hydrostatic Synthetic Transmission Fluid for me.Engine oil is fine in many hydro trannys, or as a flush, but you should really look for Deere HyGard LV for most Tuff Torq transaxles. Engine oil does not have the GL4 gear protection that you need and engine oil is not optimal for hydraulics.
Tuff Torq Recommended 5w50 Mobil 1 for years until they launched their own oil and changed all of their manuals to match.Engine oil is fine in many hydro trannys, or as a flush, but you should really look for Deere HyGard LV for most Tuff Torq transaxles. Engine oil does not have the GL4 gear protection that you need and engine oil is not optimal for hydraulics.
