TSX Under VC
Virginia
Pulled the VC for a valve adjustment. 125k miles. I purchased the car 4 years ago with 10k on it. It primarily gets PP and PureOne filters, changed out at intervals that I would get yelled at for, so I'm not going to divulge.
See all pennzoil does it sludge up engines! Nonsense, that looks great. But I'm gonna guess that's no surprise if it was 3k ocis?
Whatever the intervals are , it is clearly working. That motor is spotless.
Not super short. ~5k, depending on when the OLM starts to nag. I'm sure it could go a bit longer, but I'm too lazy to keep track of the mileage manually, so I let the dummy lights dictate.
Does the TSX require synthetic meeting HTO-6? Or does it not specify synthetic or conventional?
Pennzoil is a great oil.
Stop....go....Pennzoil.
Its like liquid ball bearings.
Nope, doesn't require HT0-6. Nor does it specify syn or conventional.
I run the PP because it keeps the valvetrain a little quieter than M1, which I ran once. I run M1 in my 4Runner, which you can see the results of here. Same story with that vehicle - OCI dictated by the dummy lights.
It has been a great car. The only issue I've had was a leaking steering rack. It started leaking about 2 months ago at about 120k miles. It took me about 5 hours (and a $350 rebuilt rack) to replace it (with the help of a buddy's lift). Not terrible. Other than that, it's just been the normal oil changes, brake pads, tires, air filter, cabin filter, and MTF changes.
It's comfortable, smooth, quick, relatively economical, and fun to drive. My commute is 110 miles round trip, and it is about as close to a perfect car for me as I could find. I wholeheartedly recommend the 6 speed. It is silky smooth and makes the car a joy to drive.
