Viscosity index is the relative change in viscosity of the oil from 40°C to 100°C. It does not precisely detail what happens at other temperatures.
The numbers Caterham posted are from the definitions of each group of base oil. There are other requirements for the base oil group classifications relating to saturates (oxygen atoms replaced by hydrogen atoms on the oil molecule) and sulfur content:
http://www.infineum.com/Documents/API/SAE Viscosity Grades for Engine Oils 2010.pdf
A finished oil product with a higher viscosity spread will by definition have a higher VI than one with a lower visc spread, i. e., a 5w30 will always have a higher VI than a 10w30.
As said above, don't put too much effort into specs. Pick an oil that the engine designer spec'ed for your engine, and look at how the choice of oils performed in engines based on used oil analyses.
