So, I picked up a Cragslist find yesterday. 1984 TroyBilt Horse III, with the 8 HP Briggs I/C engine. Engine # 1954432-0291-01
On the phone, the guy says he had a friend who "is awesome with engines" go over the tiller last year. (we all know how this ends). Get there and there is gas all over the carb. Engine isn't running at full power. Hmmm... But I bought it.
I get it home and look closer and it is really tough to see where it's coming from. The whole carb body is wet. We are talking wet above the float, on the upper body all the way up to where it joins to the intake elbow. The gasket between the the upper carb body and the intake elbow looks wet too.
I did some internet research last night and learned that these old updraft carbs love to leak. But the diagrams I saw indicated that they would leak from the bottom - there two likely failure points - one at the high speed needle on the bottom and the other at the float. But the diagrams also showed channels that would take the leakage away from the spot internally and dump it on the bottom of the air intake. I also read that these things love to leak when they are choked.
Anyway. I'm thinking a tear down is in order. I'm looking for input on what to look for, since this is the first time I've seen one of these things. Right now, I'm thinking an issue with the float/needle but that doesn't explain to me how the entire carb above the float is getting wet.
I should have left the gas turned on last night to see if it dripped when sitting, but I forgot. I'll try that today.
Appreciate any thoughts/wisdom/etc...
