Trouble with my tranny pan
Michigan
So I have a 2009 Chevy Silverado 6 liter with a Hydro matic 6 speed Automatic trans. Today I started to drop the trans pan to do a filter change and drain plug install. After taking all the bolts out I found that I don't have enough room to fully remove the pan because the exhaust crossover pipe is so close to the trans pan.
Is there a seceret to getting this pan off or do I have to unbolt the crossover pipe from the manafolds to get the pan off?
On my neighbor's Silverado, I just swapped the filter through the gap and called it good. It wasn't my vehicle so I wasn't going to mess with the exhaust.
Tried to break loose the bolts at the manafold just now after soaking them in pen. oil with my impact gun with negative results. This has turned into a no fun weekend to say the least. I also tried to drop the exhaust from the back forward but couldn't ge enough clearance. ARGH!!
If you can find it, try a penetrating oil called Mouse Milk. I used it on my 98 Yukon when it needed a new dual Cat assembly. I applied it with a Q Tip to the exhaust studs and O2 sensors while they were hot from running and disassembled everything with hand tools. The truck had 203,000 miles on it when I did this.
