Trouble After An Old-Fashioned Brake Bleed
Originally Posted By: KrisZ
I missed that, but even old pads still have to wear into the new rotors, it can be still called break in, as grooves and pattern of old rotors will be eliminated by the new rotors.
We did not install new rotors either.
All that we did was a brake bleed/flush.
Don't tape the threads on the bleeders.
It does nothing.
If you are vacuum bleeding, it won't matter.
If you are pressure bleeding, it won't matter.
If you are two man bleeding properly, it won't matter.
