Triple 7 Suspected Hydraulic System Problem
ATC audio tapes
Some speculation it could have been a failing hydraulic ADP “air driven pump”. Powered by bleed air. The exhausts for them are apparently near where the sparks were coming from.
ATC audio tapes
Thanks, that is similar to what I had heard. I'm interested because I did a lot of work on the 777 propulsion systems.
My theory is we had a failing bearing on that pump that caused a seal leak and subsequently, a hydraulic fluid leak.
The downloaded telemetry to the maintenance dept. apparently showed a problem resulting in the fuel dump and return to ground.
And yes the good news is, the pilots returned it safely.
